NX6 - Sketcher dimension text not visible
When in Sketcher mode - I want to give dimension to the sketch dimension lines are visible but dimensions text are not showing.
When i double click the dimension the dialog box for dim editing is coming up as usual but text not seeing.
Please see two images showing the sameYour file's link is:
http://files.engineering.com/getfile.aspx?folder=e...
http://files.engineering.com/getfile.aspx?folder=6...
Sunny
RE: NX6 - Sketcher dimension text not visible
Such display issues are generally caused by the graphics hardware and/or driver. Try updating the graphics driver to see if it helps. Some older "integrated" graphics hardware is not certified with NX (ie for some hardware the only viable "fix" is an upgrade).
www.nxjournaling.com
I reinstalled my graphics driver but no change..
can you upload an example partfile to this thread ?
regards,
Tomas
