Resetting the default WCS in the dialog boxes not to be the ABS WCS
Is there some way to make the WCS the default choice in the dialog boxes rather than the Absolute WCS?
It makes no sense to default to the ABS WCS when in 999 cases out of 1000 it is the WCS you have all the control over is going to be the reference origin.
RE: Resetting the default WCS in the dialog boxes not to be the ABS WCS
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
ER 6962396 Allow configuration of secondary dialogs to default to WCS instead of ABS
Does anyone also have an ER submitted for this?
Defaulting to ABS WCS in a dialog, and not having a choice of defaulting to WCS, is a major time-waster.
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
NX: Would like the option to have the Point dialog have memory
That's really NOT what I asked for. I asked to "Allow configuration of secondary dialogs to default to WCS instead of ABS".
I will call them back to clarify this.
ER#6962396 - Option to set WCS as default in Point dialog
o Short Description of desired enhancement:
-->Since the Point dialog always has the default Reference set to 'Absolute', there is no way to have the default Reference be set to 'WCS'. The user requests the ability to change the Point dialog default Reference to 'WCS'.
o What activity in your process is NX not able to currently handle?
-->Currently there is no setting or dialog memory to maintain this setting.
o What result are you trying to achieve?
-->Have 'WCS' be the default Reference in the Point dialog.
o Do you currently have a workaround?
-->Manually set the Reference to 'WCS' each time the user enters the dialog.
o Do you have a proposal for the solution you envision NX providing for this capability?
-->Add dialog memory or a customer default or preference setting so 'WCS' is the default in the Point dialog.
o What is the level of productivity gained from such an enhancement?
-->Medium
It is not only the point dialog box defaulting to the ABS WCS. All the feature creation dialog boxes like sweep and extrude default to the ABS WCS. The Move Object commands all default to the ABS WCS. Again it is 999 times out of 1000 this coordinate system does not apply and the user needs to make 4 additional totally unnessary mouse clicks to set the origin to the WCS and reset it to zero. Over a years time this is thousands of unnecessary mouse clicks.
It would be preferable to set the default in all the cammands to the WCS. This is the one that the user has all the control over and is being constantly manipulated for direction and origin of almost every feature and translation.
If you phone in an ER to GTAC, please reference this one also.
Let's see who can hold his breath for a solution the longest.............
It is curious as to why the WCS defaults to ABS. My theory is that all the database expressions that can be minipulated along with the model associativity are based on the ABS origin. The programmers may not realize that the modelers are using the WCS almost all the time for their origin and vectors.
On the older versions of Unigraphics there was the GRIP program that may have been able to fix the problem. I was not a GRIP user and may be mistaken. The older versions were able to be set to WCS once and the next time you returned to the command it was still set that way.
I don't think I will be holding my breath for a solution but we can hope...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If the whole purpose of the software was to "create fully ASSOCIATIVE, PARAMETRIC FEATURE-BASED MODELS" there would be no option to go into parameter free mode to create the model.
Oh, and here's a few capital letters for you:
As the user I do not want to have to manually change the NEVER WORKS DEFAULT presented to me 50 TIMES a day. The internal database for the features can still reference the ABS just like it will after I get through with the 4 mouse clicks that are necessary to start entering the coordinates and vectors I need to input to create the feature from the WCS.
I am designing tooling for turbine engine fan blades for major manufactures like Rolls Royce and General Electric. I take full advantage of the advanced features of NX 7.5. but do not find that a fully perametric associative model is always necessary. The molds I design require allot of free form surfaces and splitting of blocks along isocline curves for the mold parting lines. I have found that if you want to make changes it is better to use the Syncronus Technology and not depend on associativity.
Perhaps a solution can be found with a more open mind.
@John: What is wrong with a customer defaults setting to enable the wcs being the default coordinate system for some dialogs ?
Isn't it up to the user to decide if the features involved are positioned associatively or not ?
Older budweiser
NX8.5 64bit, hp z820
As for the so-called 'History-Free' approach, while that is an option, it's not the primary purpose that NX was designed for. But if you really don't care about creating fully associative, parametric models, then please, go ahead and do all your work in History-Free mode.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
As for some previous comments the dialog should remain in the state it was left in every every time. If i am subtracting something from another component the subtraction should remain "entire part" (selection scope) at lest until i exit the subtract dialog. I go from solid to solid & i have to click entire part everytime because it reverts back to "within work part". By the way "entire part is a pulldown!!!! really....3 choices & i have to click twice to get what i want!!!!
Taking it a step further, if you want the feature relative (and associative) to the "current WCS"; NX could create a datum csys on the fly and reference that. This way the feature is associated to a csys (one that saves the position of the WCS at the time the feature was created). The user could later move that datum csys as needed or associate that datum csys to other geometry. The datum csys could even be made internal to the feature as is currently possible with sketches.
I realize that the WCS is just a convenience for the user and isn't saved in a way that allows it to drive associative geometry (nor do we want it to - I'd hate for my model to change/update every time I moved the WCS). But, it seems that NX already has the groundwork in place to allow us the illusion of using the WCS, it just needs to be expanded to more commands.
www.nxjournaling.com
As to what to do next, I suggest that you open an ER (Enhancement Request) to that effect, that is, enabling Dialog Memory for this setting.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK, I get it now.
Sorry for bothering all you new users.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
We are all being inconvenienced because a new unsuspecting user might create something un-associative.
Thanks for making NX so effortless to use.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
