nx9 drafting
nx9 drafting
i'm setting my toolbars with my regular buttons.... what happened to "edit dimension associativity" even command finder doesn't find it?
RE: nx9 drafting
RE: nx9 drafting
2) the ... are sub options in the dialog. See attachment. ( note that these also can be changed upon edit)
Tomas
RE: nx9 drafting
I've pretty much decided not to use the ribbon bars, since they seem to be aimed squarely at single screen layouts with limited space..
As such, I'm putting all my common commands out on the toolbars for quick access....
I can't seem to get these extra dimension options out from the rapid dimension dialog box.
In customize I can't find how to get to them to drag out onto a toolbar, can someone help find a way?
Also someone else asked, but it wasn't resolved.....
how do you swop arrows between inside and outside, as well as turn off leaders and arrows?
I see they haven't fixed... the section line disappearing when you section from a broken view
RE: nx9 drafting
I have not tried the disappearing section line.
Tomas
RE: nx9 drafting
I can see what you see, but I can't customize my toolbar to have those options like I could in NX6.... see jpeg
RE: nx9 drafting
This is because in NX9 the new "rapid dimensioning thing", the total number of dimension types has been reduced and what in earlier versions was different types of dimensions has now become "options" of the rapid dimension. ( actually what the images I posted shows)
i.e in NX6 a "Horizontal dimension" was always a "horizontal dimension" and could never become a point to point or other type, in NX9 a "rapid dimension" can change between the different types, from Horizontal to "point to point" to angular to diameter etc
IF there is a "rapid" way of getting shortcuts to the different "options" is unknown.
Tomas
