wear tire noise away
2010 Dodge Caliper. Toe adjustment only on front and rear wheels. 2nd set of tires in 75,000 miles. Original tires went 35K then one scalloped and feather edge on inside. Tire got loud and you could feel the feather edge all around the indie edge of the tire. I replaced the tires with Michelin HydroEdge "directional" tires, 90,000 miles. After 35k miles the noise came back. One bad tire in four. Tires have been rotated every 5,000 miles. car has been aligned 5 times in 3 years. Noise starts getting bad at 55mph and gets worse from there. My question is how can i wear the bad tire on the inside edge to smooth out the scalloping? Tire has good tread left on it. It is the rear driver side position that is causing the initial trouble.
Peter
Peter
RE: wear tire noise away
In spite of the fact that the factory didn't provide adjustability, it can be adjusted. It may require an eccentric bolt or a camber plate, but it can (and should be done).
I am of the opinion that published factory alignment tolerances are too wide - by half. Put another way, the alignment needs to be within the inner half of the tolerance to insure good tire wear.
Also, any time there is over a degree of camber, the risk of tire wear issues escalates.
So looking at the alignment specs for a Dodge Caliber, I notice that the alignment tolerances are the usual - too wide - and they specify a camber that is near a degree and could be over a degree with the allowable tolerance. So I think you need to have the camber dialed out as best you can.
But to answer your question: Have the tire dismounted off the wheel and remounted inside out. There is a strong possibility that even that will not cause the tire to wear back evenly. What is more likely is that a new wear pattern will be worn on top of the old wear pattern, but not erase the old one.
Norm
Yes, you will have to swap 2 to get the whole thing to work. Just be aware that unless you fix the alignment, you'll be generating more tires with problems.
Camber front -1.0
Camber Rear -.8
toe front total .16
toe rear total .18
caster all around 2.6
