Can a Venturi be used in a wind tunnel to suck out the walls, ceiling and floor boundary layer?
Using the air flow already created by the fans to divide the airflow in two sections a straight inner section and a (curved) Venturi outer section that sucks out the boundary layer thru holes in the test section area.
Something like this
Would this array need extra flow straighteners?
Does the straight tunnel section need to be longer approaching the fans to ensure consistent suction (as depicted in the image?
Any other improvements you would advice?
thanks guys
Something like this
thanks guys
RE: Can a Venturi be used in a wind tunnel to suck out the walls, ceiling and floor boundary layer?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
