Tabular note chart using WCS x, y, z coordinates
I have a journal I found on this site that works great for absolute coordinates, but need to read WCS coordinates and place in a chart. We are required to use end of part, not in car body coordinates.
Does anyone know what the code is to change to reading WCS x,y,z of a point? Below is the code I am using. I appreciate any help on this.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Annotations
Imports NXOpen.UI
Imports NXOpen.UF
Imports NXOpen.Utilities
Module create_tabnote_with_all_3d_points_coordinates
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim ui As UI = UI.GetUI()
Dim lw As ListingWindow = s.ListingWindow
Dim workPart As Part = s.Parts.Work
Sub Main()
Dim startcell0 As String = "FORM POINTS TO BE CHECKED"
Dim xvalue As Double = Nothing
Dim response1 As Selection.Response = Selection.Response.Cancel
' Get a view for the IDs
Dim dwgview As View = Nothing
If select_a_drawing_member_view (dwgview) <> Selection.Response.Ok Then
Return
End If
' Get a location for the tabular note
Dim cursor As Point3d
Dim response As Selection.DialogResponse = SelectScreenPos(cursor, dwgview)
If response <> Selection.DialogResponse.Pick Then
Return
End If
' Create the tabular note
Dim n_new_columns As Integer = 4
Dim tabnote As NXOpen.Tag = CreateTabnoteWithSize(0, n_new_columns, cursor)
' Get the column tags
Dim columns(n_new_columns - 1) As NXOpen.Tag
For ii As Integer = 0 To n_new_columns - 1
ufs.Tabnot.AskNthColumn(tabnote, ii, columns(ii))
Next
Dim pt1 As Point = Nothing
Dim row As NXOpen.Tag
Dim cell As NXOpen.Tag
Dim cells(3) As NXOpen.Tag
' add start row1
' FORM
ufs.Tabnot.CreateRow(35, row)
ufs.Tabnot.AddRow(tabnote, row, UFConstants.UF_TABNOT_APPEND)
For i As Integer = 0 To 3
ufs.Tabnot.AskCellAtRowCol(row, columns(i), cells(i))
Next
ufs.Tabnot.MergeCells(cells(0), cells(1))
ufs.Tabnot.MergeCells(cells(2), cells(3))
ufs.Tabnot.MergeCells(cells(0), cells(2))
ufs.Tabnot.SetCellText(cells(0), startcell0)
' Add points Header Row
Dim headerrow As NXOpen.Tag
ufs.Tabnot.CreateRow(30, headerrow)
ufs.Tabnot.AddRow(tabnote, headerrow, UFConstants.UF_TABNOT_APPEND)
ufs.Tabnot.AskCellAtRowCol(headerrow, columns(0), cell)
ufs.Tabnot.SetCellText(cell, "POINT #")
ufs.Tabnot.AskCellAtRowCol(headerrow, columns(1), cell)
ufs.Tabnot.SetCellText(cell, "X")
ufs.Tabnot.AskCellAtRowCol(headerrow, columns(2), cell)
ufs.Tabnot.SetCellText(cell, "Y")
ufs.Tabnot.AskCellAtRowCol(headerrow, columns(3), cell)
ufs.Tabnot.SetCellText(cell, "Z")
Dim letteringPrefs As LetteringPreferences = Nothing
Dim userSymPrefs As UserSymbolPreferences = Nothing
Dim markId1 As Session.UndoMarkId
markId1 = s.SetUndoMark(Session.MarkVisibility.Visible, "Start")
Dim jj As Integer = 0
Dim id As Integer = 1
start1:
' Add one row for each point
response1 = select_a_point(pt1)
If response1 <> Selection.Response.Ok Then GoTo end1
' For Each pt As Point In pcol1
id = jj + 1
' Get the Coordinates
Dim pt3d As Point3d = pt1.Coordinates
' Add a row for each point
ufs.Tabnot.CreateRow(30, row)
ufs.Tabnot.AskCellAtRowCol(row, columns(0), cell)
ufs.Tabnot.SetCellText(cell, id.ToString())
' Set the cell text
ufs.Tabnot.AskCellAtRowCol(row, columns(1), cell)
ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.X, 3).ToString())
ufs.Tabnot.AskCellAtRowCol(row, columns(2), cell)
ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.Y, 3).ToString())
ufs.Tabnot.AskCellAtRowCol(row, columns(3), cell)
ufs.Tabnot.SetCellText(cell, FormatNumber(pt3d.Z, 3).ToString())
' Add ID notes to the points
AddNoteToPoint(id, pt1, pt3d, dwgview)
jj = jj + 1
Dim markId2 As Session.UndoMarkId
markId2 = s.SetUndoMark(Session.MarkVisibility.Invisible, "Note")
GoTo start1
end1:
End Sub
Public Function SelectScreenPos(ByRef pos As Point3d, ByVal view As View) As Selection.DialogResponse
Return ui.SelectionManager.SelectScreenPosition("Select location for tabnote", view, pos)
End Function
Function select_a_drawing_member_view(ByRef dwgview As View) As Selection.Response
Dim mask(1) As Selection.MaskTriple
mask(0).Type = UFConstants.UF_view_type
mask(0).Subtype = UFConstants.UF_view_imported_subtype
mask(0).SolidBodySubtype = 0
mask(1).Type = UFConstants.UF_view_type
mask(1).Subtype = UFConstants.UF_view_orthographic_subtype
mask(1).SolidBodySubtype = 0
Dim cursor As Point3d = Nothing
Dim vw As View = Nothing
Dim resp As Selection.Response = _
ui.SelectionManager.SelectObject("Select Points Drawing View", _
Selection.SelectionScope.AnyInAssembly, _
Selection.SelectionAction.ClearAndEnableSpecific, _
False, False, mask, vw, cursor)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Then
dwgview = CType(vw, View)
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Public Function CreateTabnoteWithSize( _
ByVal nRows As Integer, ByVal nColumns As Integer, ByVal loc As Point3d) As NXOpen.Tag
Dim secPrefs As UFTabnot.SectionPrefs
ufs.Tabnot.AskDefaultSectionPrefs(secPrefs)
Dim cellPrefs As UFTabnot.CellPrefs
ufs.Tabnot.AskDefaultCellPrefs(cellPrefs)
cellPrefs.zero_display = UFTabnot.ZeroDisplay.ZeroDisplayZero
ufs.Tabnot.SetDefaultCellPrefs(cellPrefs)
Dim origin(2) As Double
origin(0) = loc.X
origin(1) = loc.Y
origin(2) = loc.Z
ufs.Tabnot.Create(secPrefs, origin, tabnote)
' Delete all existing columns and rows (we create them as needed)
Dim nmRows As Integer = 0
ufs.Tabnot.AskNmRows(tabnote, nmRows)
For ii As Integer = 0 To nmRows - 1
ufs.Tabnot.AskNthRow(tabnote, 0, row)
ufs.Tabnot.RemoveRow(row)
ufs.Obj.DeleteObject(row)
Next
Dim nmColumns As Integer = 0
ufs.Tabnot.AskNmColumns(tabnote, nmColumns)
For ii As Integer = 0 To nmColumns - 1
Dim column As NXOpen.Tag
ufs.Tabnot.AskNthColumn(tabnote, 0, column)
ufs.Tabnot.RemoveColumn(column)
ufs.Obj.DeleteObject(column)
Next
' Now add our columns as needed
Dim columns(nColumns - 1) As NXOpen.Tag
For ii As Integer = 0 To nColumns - 1
ufs.Tabnot.CreateColumn(35, columns(ii))
ufs.Tabnot.AddColumn(tabnote, columns(ii), UFConstants.UF_TABNOT_APPEND)
Next
' Now add our rows as needed
Dim rows(nRows - 1) As NXOpen.Tag
For ii As Integer = 0 To nRows - 1
ufs.Tabnot.CreateRow(10, rows(ii))
ufs.Tabnot.AddRow(tabnote, rows(ii), UFConstants.UF_TABNOT_APPEND)
Next
Return tabnote
End Function
Public Sub AddNoteToPoint(ByVal id As Integer, ByVal pnt1 As Point, _
ByVal pt As Point3d, ByVal dwgview As View)
Dim screenpos As Point3d
SelectScreenPoint(screenpos)
Dim nullAnnotations_SimpleDraftingAid As Annotations.SimpleDraftingAid = Nothing
Dim draftingNoteBuilder1 As Annotations.DraftingNoteBuilder
draftingNoteBuilder1 = workPart.Annotations.CreateDraftingNoteBuilder(nullAnnotations_SimpleDraftingAid)
draftingNoteBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(True)
draftingNoteBuilder1.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.MidCenter
Dim text1(0) As String
text1(0) = "F " & id.ToString
draftingNoteBuilder1.Text.TextBlock.SetText(text1)
Dim leaderData1 As Annotations.LeaderData
leaderData1 = workPart.Annotations.CreateLeaderData()
leaderData1.StubSize = 5.0
leaderData1.Arrowhead = Annotations.LeaderData.ArrowheadType.FilledArrow
draftingNoteBuilder1.Leader.Leaders.Append(leaderData1)
leaderData1.StubSide = Annotations.LeaderSide.Inferred
leaderData1.Leader.SetValue(pnt1, dwgview, pt)
Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData
assocOrigin1.OriginType = Annotations.AssociativeOriginType.RelativeToGeometry
Dim nullView As View = Nothing
draftingNoteBuilder1.Origin.Origin.SetValue(Nothing, nullView, screenpos)
Dim nXObject1 As NXObject
nXObject1 = draftingNoteBuilder1.Commit()
draftingNoteBuilder1.Destroy()
End Sub
Public Function select_a_point(ByRef pt1 As Point) As Selection.Response
Dim mask(0) As Selection.MaskTriple
With mask(0)
.Type = UFConstants.UF_point_type
.Subtype = 0
End With
ufs.Ui.SetCursorView(0)
ufs.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
ui.SelectionManager.SelectObject("Select a point", "Select a point", _
False, False, mask, pt1, cursor)
ufs.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
ElseIf resp = Selection.Response.Back Then
Return Selection.Response.Back
Else
End If
End Function
Function SelectScreenPoint(ByRef screenpos As Point3d)
Dim displayPart As Part = s.Parts.Display
Dim baseView1 As View = s.Parts.Work.Views.WorkView
Dim point As Double() = {0.0, 0.0, 0.0}
Dim response As Integer = 0
Dim viewTag As Tag = Nothing
Dim viewType As UFView.Type = Nothing
Dim aView As View = Nothing
Dim viewSubtype As UFView.Subtype = Nothing
ufs.Ui.SetCursorView(1)
Try
ufs.Ui.SpecifyScreenPosition("Select Label Pos", Nothing, IntPtr.Zero, point, _
viewTag, response)
Finally
End Try
If (response <> NXOpen.UF.UFConstants.UF_UI_PICK_RESPONSE) Then Return Selection.Response.Cancel
screenpos.X = point(0)
screenpos.Y = point(1)
screenpos.Z = point(2)
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
RE: Tabular note chart using WCS x, y, z coordinates
Hi cowski,
Thank you for the link. Sorry took so long to get back to you. Only have one more question. Where do I insert it? Figured need to put it before start1: line, but does not work. Tried several other things with no luck. Any help would be appreciated!
