Reset components to absolute?
CATIA has a function whereby it displays the translation and rotation of a component from absolute also allowing you to edit its position and reset to absolute.
I cant find anything similar in NX which will allow me to quickly reset a component back to absolute in both translation and rotation.
I currently use either move component Csys to Csys or insert a new instance at absolute.
Does anyone know of a quicker way or perhaps a journal which could rest a component back to the displayed part Absolute?
Khimani.
Khimani.
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
RE: Reset components to absolute?
thread561-311299: How can you tell if a component has been moved.
www.nxjournaling.com
theSession.UpdateManager.InterpartDelay = True
Khimani Mohiki
NX8.5
Khimani Mohiki
NX8.5
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Module componentOriginalPosition Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager Sub Main() Dim selectedComponent As NXObject If SelectComponent(selectedComponent) = Selection.Response.Cancel Then Exit Sub End If Dim myInterpartDelay As Boolean = theSession.UpdateManager.InterpartDelay Dim pt As Point3d Dim RotMat As Matrix3x3 Dim pt2 As Vector3d Dim RotMat2 As Matrix3x3 Dim SelComp As NXOpen.Assemblies.Component SelComp = selectedComponent SelComp.GetPosition(pt, RotMat) 'msgbox("Translation: " & pt.x & ", " & pt.y & ", " & pt.z) 'msgbox("Rotation: " & vbcrlf & _ ' RotMat.xx & ", " & RotMat.xy & ", " & RotMat.xz & vbcrlf & _ ' RotMat.yx & ", " & RotMat.yy & ", " & RotMat.yz & vbcrlf & _ ' RotMat.zx & ", " & RotMat.zy & ", " & RotMat.zz) 'no translation of component on first pass pt2.X = 0 pt2.Y = 0 pt2.Z = 0 'transpose of the rotation matrix, undo any rotations on the component RotMat2.Xx = RotMat.Xx RotMat2.Xy = RotMat.Yx RotMat2.Xz = RotMat.Zx RotMat2.Yx = RotMat.Xy RotMat2.Yy = RotMat.Yy RotMat2.Yz = RotMat.Zy RotMat2.Zx = RotMat.Xz RotMat2.Zy = RotMat.Yz RotMat2.Zz = RotMat.Zz 'avoid problems if the part contains wave links or other interpart data theSession.UpdateManager.InterpartDelay = True 'move the component back to the original rotation workPart.ComponentAssembly.MoveComponent(SelComp, pt2, RotMat2) 'get the translation information again, now that the component has been rotated back to absolute SelComp.GetPosition(pt, RotMat) 'negate the translations that have been applied to the component pt2.X = -pt.X pt2.Y = -pt.Y pt2.Z = -pt.Z 'set rotation matrix to identity matrix, we want no new rotations on the component 'or simply use RotMat returned from GetPosition, as it will be the identity matrix 'after the component has been rotated back to its original position RotMat2.Xx = 1 RotMat2.Xy = 0 RotMat2.Xz = 0 RotMat2.Yx = 0 RotMat2.Yy = 1 RotMat2.Yz = 0 RotMat2.Zx = 0 RotMat2.Zy = 0 RotMat2.Zz = 1 'translate component back to 0,0,0 workPart.ComponentAssembly.MoveComponent(SelComp, pt2, RotMat2) 'reset interpart delay to original value theSession.UpdateManager.InterpartDelay = myInterpartDelay End Sub Function SelectComponent(ByRef selObj As NXObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim message As String = "Select Component" Dim title As String = "Select an object" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(message, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selObj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function '****************** Public Function GetUnloadOption(ByVal dummy As String) As Integer GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY End Function End Modulewww.nxjournaling.com
