Easy SAFE question
Easy SAFE question
I feel a little silly asking this but here go's. How do you move two points at once? I need to move a column to a different point. I want to use the visual modify tools to do this but I can’t seem to pick the column and move it based on the top of column node. Any ideas? I need to move heaps of columns and would just be so much simpler to move it like this rather than checking distance, XYZ coordinates, etc. Can anyone help?
O
O
RE: Easy SAFE question
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
