Ball Valve with Extended Stem
I am trying to find manufacturers of a bronze body ball valve (nothing fancy; 300 psig WOG HVAC service) that offer extended stems.  Ideally, I would like to find not only an extended stem, but an extended body around the stem, so that I can seal my insulation to the body just below the handle.  Apollo offers extended stems, but not an extended body.
My problem is that when using standard ball valves in chilled water service, if they need to be operated with any frequency, it is almost impossible to maintain a vapor barrier around the stem region.
I'm posting this on the HVAC forum as well. Any suggestions would be greatly appreciated.
---KenRad
RE: Ball Valve with Extended Stem
Kenrad,
Problem is well known. An extended stem only will
have the problem that it will turn in the insulation,
if operated.
So you will need an extended stem with a protection tube
around the stem, protection tube is attached to the valve.
We made this several times, only thing you need is a valve with a mounting pad/topflange.
There are no valve manufacturers, as far as i'm aware, that make this extension.
richardhoorn,
Thanks for the help!
---KenRad
KenRad,
Wabtec Corporation makes custom ball valves for railroads and industrial uses.
We can adapt our valves to fit just about any customer's needs.
Mike
mveltri@wabtec.com
