NX6 Import > Part using drawing borders creates multiple entities in groups
I'm using NX6
I created a drawing border for a customer, moved it to the templates folder, and modified the .pax file.
If I insert it using the template or even use the Import > Part command and select the .prt file, I get a border that contains not only the original lines, but also contains 2 extra lines for each entity listed as (in group) How can I keep this from happening?
RE: NX6 Import > Part using drawing borders creates multiple entities in groups
www.nxjournaling.com
