automatic image creation
hello,
I have seen a journal to take a jpg image of each part and assembly that exists in the model but was wondering if we can take the image to be more precise. Only the bounding area of each displayed part to be in the created image? basically to reduce the whitespace around and to reduce the file size and to get a crisper image.
thanks for the help
DPRK
thanks for the help
DPRK
RE: automatic image creation
www.nxjournaling.com
thanks for the help.
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
theSession.Preferences.ScreenVisualization.TriadVisibility = 0
' TO get the folder name for jpgs
Dim folderName As String = "C:"
Dim folderBrowserDialog1 As New FolderBrowserDialog
With folderBrowserDialog1
.Description = "Specify folder for screenshot output"
.ShowNewFolderButton = False
.RootFolder = Environment.SpecialFolder.Desktop
'use folderName as default directory
.SelectedPath = folderName
End With
Dim result As DialogResult = folderBrowserDialog1.ShowDialog()
If (result = DialogResult.OK) Then
folderName = folderBrowserDialog1.SelectedPath
Else
'user pressed cancel, exit the journal
Exit Sub
End If
'lw.Open
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
'lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
'lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'lw.WriteLine(folderName & "\" & c.RootComponent.DisplayName)
'*** end of code to process root component
Dim nullAssemblies_Component As Assemblies.Component = Nothing
Dim partLoadStatus3 As PartLoadStatus
theSession.Parts.SetWorkComponent(nullAssemblies_Component, partLoadStatus3)
workPart = theSession.Parts.Work
partLoadStatus3.Dispose()
dispPart.ModelingViews.WorkView.Fit()
dispPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Isometric, NXOpen.View.ScaleAdjustment.Fit)
dispPart.ModelingViews.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.ShadedWithEdges
dispPart.Preferences.NamesBorderVisualization.ShowModelViewNames = False
For i As Integer = 2 To 256
Dim stateArray1(0) As Layer.StateInfo
stateArray1(0) = New Layer.StateInfo(i, Layer.State.Hidden)
dispPart.Layers.ChangeStates(stateArray1, False)
Next
Dim strPartJpg As String = ""
strPartJpg = Path.GetFileNameWithoutExtension(dispPart.FullPath) & ".jpg"
strPartJpg = Path.Combine(folderName, strPartJpg)
ufs.Disp.CreateImage(strPartJpg, UFDisp.ImageFormat.Jpeg, UFDisp.BackgroundColor.White)
ReportComponentChildren(c.RootComponent, 0, folderName, theSession)
else
'*** insert code to process piece part
'lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
'lw.Close
End Sub
Sub reportComponentChildren( ByVal comp As Component, _
ByVal indent As Integer, ByVal fName As String, ByVal theSes As Session)
For Each child As Component In comp.GetChildren()
'*** insert code to process component or subassembly
'lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
'lw.WriteLine(New String(" ", indent * 2) & fName & "\" & child.DisplayName())
Dim Part1 As Part = CType(theSes.Parts.FindObject(child.DisplayName()), Part)
Dim partLoadStatus1 As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSes.Parts.SetDisplay(Part1, True, True, partLoadStatus1)
Dim workPart As Part = theSes.Parts.Work
Dim displayPart As Part = theSes.Parts.Display
workPart = theSes.Parts.Work
displayPart = theSes.Parts.Display
partLoadStatus1.Dispose()
displayPart.ModelingViews.WorkView.Fit()
displayPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Isometric, NXOpen.View.ScaleAdjustment.Fit)
displayPart.ModelingViews.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.ShadedWithEdges
displayPart.Preferences.NamesBorderVisualization.ShowModelViewNames = False
theSes.Preferences.ScreenVisualization.TriadVisibility = 0
displayPart.Layers.ChangeStates(stateArray1, False)
Next
strPartJpg = Path.GetFileNameWithoutExtension(displayPart.FullPath) & ".jpg"
strPartJpg = Path.Combine(fName, strPartJpg)
'Dim markId As Session.UndoMarkId
'markId = theSes.SetUndoMark(Session.MarkVisibility.Visible, "Display Parent")
'*** end of code to process component or subassembly
if child.GetChildren.Length <> 0 then
'*** this is a subassembly, add code specific to subassemblies
'lw.WriteLine(New String(" ", indent * 2) & _
'"* subassembly with " & _
' child.GetChildren.Length & " components")
'" + Active Arrangement: " & _
'child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
'*** end of code to process subassembly
else
'this component has no children (it is a leaf node)
'add any code specific to bottom level components
end if
reportComponentChildren(child, indent + 1, fName, theSes)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
thread561-331483: Export pdf from modeling, with dim or hidden edges?
Short description: change your view fit percent to 100 before exporting the screenshot and there is code that will crop out some white space.
