Booster pump for cooling coil
Hello All, I have an application where I need to install a new cooling coil in an existing 30% water/ glycol distribution loop. The existing distribution loop has a 50 psig differential pressure set point across the supply and return piping maintained by a VFD driven pump. At full flow the new coil needs 90 psig. The existing pumps are not sized to provide any added pressure. I want to install a booster pump to the supply pipe to the coil to provide this added pressure.
Who makes this type of pump? Any pitfalls with this approach? All help is appreciated.
RE: Booster pump for cooling coil
I have never heard of a coil requiring 90 psig. Must have lots and lots of rows.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
I (and all my maintenance staff) would recomment to never isntall Taco / Armstrong. Unless leaking is not a problem. Especially since glycol leaks even more than water.
