Autocad lisp for P.T Slab cable Profile
Hi mates,
I`m new to this forum,
I`m using RAM CONCEPT FOR P.T DESIGN
I need cables elevation from slab soffit at max 1 meter spacing.
RAM only produce the high and low points of the cable
is there an autocad lisp to produce cable elevation at max spacing of 1 meter
or any other ideas to make such a thing.
thanks for your cooperation.
RE: Autocad lisp for P.T Slab cable Profile
Welcome to Eng-Tips.
Sorry, can't help you, but that sucks that RAM CONCEPT does not profile the PT tendons at user-selected max spacings.
I use RAPT and it has great functionality for PT profiling.
Since you have the high and low points, as well as the inflection point location you can set up some parabola equations to get you the remaining points.
Thanks gays for fast reply I consider that as worm gesture of welcoming.
gays? worm gesture? Oh, what the hell, welcome anyway.
BA
