Friendly Competition Between Engineering Firms
Hi ladies and gents
Have a wood bridge building competition between a few structures firms in my area through MdQi (http://mdqi.org/), and I am looking to load test the wood pieces somehow. We were given these packs of very small (maybe 4 times the cross section area of a toothpick) pieces of wood. I checked the manufacturer, and all I could determine is that they were made in China...they are probably 10% wood 90% asbestos or some other weird material.
Anyways, would anybody have any suggestions as to how I could quantitatively perform tensile, compression, and maybe bending tests on these little sticks?
Or - would it be better suited to assume a wood with poor mechanical properties and directly calculate?
*My* gut feeling is that applying assumed mechanical properties is going to be way off how they actually behave.
RE: Friendly Competition Between Engineering Firms
1. What you need to know "exactly" how much the "average" wood stick performs: tension, rigidity (which comes from all three of straightness and tolerances in size over the length AND material properties varying over the length as well!), strain, etc. all combine.
2. But the "average" Chinese-made "wood stick" doesn't matter either: You're going to be making a structure up from several dozen (hundred?) of the d*mn things, and you need to either test several hundred (not to failure!) and select the best several dozen (which isn't quite cheating, merely "prudently gathering materials") for the actual product.
Alternately, you could test several dozen to destruction, then determine what you will accept as the mean of the structural and physical properties from that batch as a "good enough" average for the entire potential group of "wood sticks" to determine adequate design criteria.
If you do decide to use the "average" properties, then you're penalizing yourself from the start because you HAVE to accept that some 5% percent will be "below spec" by more than 2x standard deviations. So, do you overbuild so those failing 5% of the sticks won't crash your project? Or test the entire provided lot so you eliminate the worst 5%, but can assume the remaining 95% that survived the "test-just-short-of-failure" test are at nominal strength (or above)?
Avoid ANY chance of your test results getting to the competition! Avoid even the hint that you are testing your sticks statistical properties (material OR physical) ahead of time. It will give the competition too many ideas.
Consider a quick go/no-go gage if you are given your sticks only at the time of competition: Throw out the skinny or "wavy" sticks or bent sticks, accept for use only those "above average" in thickness and depth. Warning: If your project "winning" is determined by weight-of-bridge and not just capacity-of-bridge, then watch also the weight of tape, glue and fasteners as well as weight of the sticks.
The problem I am running into how to contrive/build or find testing devices. Finding devices to borrow or rent seems improbable. Building testing devices seems complex as they have to deliver constant and concentric forces, while having the ability to measure the force. That is were I need the most suggestions! :)
The main criteria is load-to-weight efficiency, and we are limited to 400 grams total. I have already looked into finding a reasonable adhesive with the lowest specific gravity possible to limit weight.
So, try a simpler pull-to-failure test using weights attached to a member to determine the limiting condition: Joint strength in tension or member strength. fasten three or four members together in a line using various glues/epoxies/or wood-cynoacrylics (superglues - wood superglues are at many wood hobby shops and on-line) or cyno-acrylics plus a pin to increase shear strength. Increase the weight until either a joint fails or the wood fails. Try various double-sided joints against single-sided joints: The double side increases glue area (net joint strength) and creates an even pull on both sides of the wood stick, but requires twice as much weight.
Typical twisting resistance (S) of a member? Use a very, very small torque wrench with the other end of the member clamped in a vise.
http://www.generaltools.com/S94--Single-End-Pin-Vi...#
I imagined placing a piece in a vice and torquing it until it fails - however, how to measure the clamping force? It seems like the testing device needs to measure it directly, since I don't have constitutive properties to get back to the force from the deformation.
Think of every way you can cheat, then check the rules to see if it is actually cheating, or if the rules are silent on the topic.
Tie helium balloons to your bridge right before the weigh in and competition.
You must be a fan of steroids in baseball too!
After drying, what ever the glue/epoxy/cyanoacrylate itself provides is all the "clamping" force you can use.
Now, let's pretend you've developed a "perfect design" that is extremely lightweight but has two "bad joints" where you need more clamping force, or a thicker diameter pin that also provides a clamping force, or something like that. Then, at that failure point, you add a nbr 4 or nbr 6 or a nbr 8 machine screw and clamp the two or three or four wood sticks together.
Each bridge shall be built using craft sticks (supplied in your kit) and
glue (supplied by participant). The bridges will have a Span Length of 20
Inches and a maximum bridge weight of 400 grams.• Each Bridge will be loaded to failure as determined by the Judges.
• The overall winner will be based upon an efficiency index determined
by dividing the weight the bridge holds in pounds by the weight of the
bridge in grams. The highest efficiency rating wins.
Details here
http://mdqi.org/images/stories/mdqi_documents/2014...
Cheers
Greg Locock
Greg: Yeah, the rules are pretty simple and open for all sorts of things - no glue rules and such.
Cheers
Greg Locock
Define "glue" - LOL.
How about "glue" = resin reinforced with carbon fiber? Otherwise known as carbon fiber.
Of course you'll need to include a smattering of wood. Convert a couple of wood bits to veneer on a wee tiny lathe, and use a few milligrams of veneer to decorate a few small sections of the
carbon fiber... sorry, "wood and glue" bridge.RE: Friendly Competition Between Engineering Firms
I always like to say "rules are rules, and not rules are not rules."
Can you use a toothpick (a shiskabob-type round skewer would be about the right diameter) or only wooden craft (Popsicle) sticks?
I also thought about slicing the sticks in half and cross-laminating them into a sheet with epoxy and cut out gusset plates from the sheets.
Now, remember that you don't need a 'pin" at every joint, only that 20% most highly loaded. (Even in simple Wrren truss, not every beam and span is equally loaded).
So, if you laminated 4x popsicle sticks together, your original 0.0937 flat stick is now a 3/8 x .375 thick square beam. So cut that beam into 4x sq pins, and insert those pins into the most threatened joints. If a sq hole is difficult, and it will be hard to do either automatically or manually, put the sq pins on a lathe and turn them down to a 3/16 diameter round shape. From a single 3/8 x 3/8 x 4 inch beam, you get 4x 4 inch long 3/16 pin rolls, for 20-30 pins. Then use a drill to drill the holes.
Remeber, rules said glue and wood sticks. Didn't say anything about "how" you're gluing the sticks together.
Assume you need a long tension member.
Which would be more efficient (greatest tension force sustained at failure)/(total weight of the tension member)?
A string of 4 inch long x 0.0937 thick x 3/8 wide popsicle sticks glued at each end (so they overlap by 3/8 inch)?
Or a double-thick string of popsicle sticks but with each popsicle stick overlapped with its neighbor for gluing surface 2 inches long at end? Note that, since the popsicle sticks can be narrowed down (from 3/8 thick to perhaps 3/16 thick), the net extra strength would be useful since the 'ply" effect of two layers of wood add up?
I have been thinking about the topology of the truss bridge, and wondering if it would be worth it to try to get a demo of a optimization program. My quick Google search landed me on Solidworks and Genesis by VR&D.
I did find this seemingly primative portable optimization program (http://www.upct.es/~deyc/software/tto.php), but it is rather clunky to use and there isn't much for options - it doesn't seem to give a rats rear-end about member length or provide an output to .dxf. Check it out though - I have never seen anything like it.
The load is essentially a point load at the center, so I would think that the general shape should be a triangle to mimic the moment diagram, but am curious if an optimization software could provide me a more detailed topology where I can constrain member lengths (to keep as many as I can to the length of the wood sticks), and maybe control a few other variables too.
