Required embedment for a timber pile into a concrete pile cap.
I am trying to find a detail for timber piles into a concrete pile cap. I searched our company library, the Timber Piling Council, and checked Google and could not come up with a detail with confidence.
Basically we have 12" timber piles with a concrete pile cap on grade supporting a shallow water tank. There is no uplift and very little shear in the cap. Does anyone know a reference for the connection of the piles to the cap?
Is this detail as simple as saying embed the pile 6"
Or is there an obscure code requirement that we need to run rebar thru the top?
Thank you
Thank you
RE: Required embedment for a timber pile into a concrete pile cap.
I have expanded my google searching and have come up with a few references that are right in line with what has been said
6" - Design of Marine Facilities for the Berthing, Mooring, and Repair of Vessels
4" embedment minimum for piles not in tension - ASCE/SEI 24-98 Flood resistant design and construction -
12"-24" depending on the situation - Ohio DOT:
6" - CRSI
