Defined integral, but one limit needs to be found
Hi guys!
Need a little help couse Mathcad doesnt allow me to deine the integral limit as the unknown.
Simple egsample:
integral of "x dx" with limits "a=0 and b=5".
The solution is 12.5
How to reverse the situation so that a=0, b=unknown and provide the previous result of 12.5?
I want Mathcad to find the b value.
How to do this?
Thanx
RE: Defined integral, but one limit needs to be found
"solve block"
Is that a command inside Mathcad or something else?
...and you like to drink wich beer and how much? smile
One more question, and thenx for the previous answer.
How to use the result you get?
Im asking this becasue if I have even the simpliest equation like 2x+3=0, in Mathcad I would get -3/2 using the "solve for x".
But how to use the x value (-3/2) for your further calculations?
Root functions seems to work for this couse I can get numeric value.
Anyother ideas?
"But how to use the x value (-3/2) for your further calculations?"
That would depend on what you're doing, wouldn't it? Presumably, x is something you needed. If you didn't need the solution, then there wouldn't be any point in solving for it, would there?
TTFN
Sorry I dont understand you sad
Something on "root" function?
No, I think he means -->solve,x and it doesn't work.
AnaAnt: What you have to do is --- x:=1 (or something) then Given [CR] 2*x+3:=0 [CR] x:=Find(x). After Given you have to use [CRTL]= just like before.
Thanx smile
Hi guys.
One more question on root function in MATHCAD.
Plase look at the file attached.
When I try to calculate t(x)=0 and find the the x value "by hande" I get an quadriatic equation with x1 and x2.
Using the root function in Mathcad I always get warning message saying "divide by zero" sad
What am I doing wrong?
Thank you.
Quote (mar2805)
You tell Mathcad to search for a solution in the range from 0 to h.
Look at your function - what happens for x=0? (Tip: look inside the square brackets winky smile).
So replace the 0 for something like 10^-2 mm (you need to add the unit) and you get 135.017mm.
As an alternative you can use root another way:
x:=1m // guess value needed
z:=root(t(x),x)
I typed integrate(x^2,0,b)=12.5,solve,b and it returned 5 and -5.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
Quote (PNachtwey)
Thats one of the possible ways to answer the original question which I posted here 12 days ago. See above.
Was this a question of yours?
Quote:
Quote (PNachtwey)
Just saw it - I hope you didn't really type x^2, otherwise this would mean you have a corrupt copy of mathcad winky smile
I am having a similar issue in that I use a solve block to solve for two unknowns say C1 & C2. I use the Find(C1,C2) and it gives me the values in a 1x2 Matrix form. After the solve/find block I would like to use C1 and C2 in further equations but they are not defined. I have to manually set C1= to the value I see in the find block. How do I define C1 & C2 as the values in the Find block?
Occupant above gave an example that works when there is one undefined variable ie. C1 := Find(C1) but I can't get it to work with 2 unknowns.
Tried something like this C1,C2 := Find (C1,C2) ..... or defining them separately C1 := Find(C1) C2 := Find(C2). It wont solve when I break it up.
Shinerttu…
You can extract values from vectors and matrices by using array subscripts. For example (and asusming ORIGIN=0), if you have Res:=Find(C1,C2)=[C1 C2], you can get C1 out of the result vector by using Res[0= and you can get C2 by using Res[1=. The "[" keystroke gets you the array subscript. If ORIGIN=1, then use 1 and 2 as your array subscripts.
--Winston S. Churchill
Occupant/fel3 thanks!
