Gear pump pressure
Gear pump pressure
i have a setup where i uses a small gear pump. It is a brushless pump with a inner controller. It is max 10 bar, max 1liter per min. The seller told me when it 0.1 Lpm it would be at around 7 bar. However when i regulate the flow with the controller, my pressure gauge doesnt show any pressure change however there is flow rate changes. I was wondering is this how gear pump works? Do i need to use a throttling valve to make the pressure go up? What do i need to make the liquid have around 7 bar pressure at downstream.
RE: Gear pump pressure
So yes, if for whatever reaosn you want a higher presusre downstream of your pump at a given flow, then you need to raise the system pressure atrificially by means of a throttling valve or other device to restrict flow - e.g. an orifice plate or smaller diameter tubing.
Note that as pressure builds, your motor will likely being to slow down, and fluid slip in the pump will increase, therefore you will see a dip in flow.
