Shaded view on a drawing ~ NX7.5
I have a shaded view on a drawing but it only prints in wireframe.
When I go to File->Print, the only two output options that I have are B&W wireframe and color wireframe.
So is it possible to print a shaded drawing image as a it shows up on the drawing ?
RE: Shaded view on a drawing ~ NX7.5
www.nxjournaling.com
I looked at NX7.5 and it does have the option "Export shaded geometry as Wireframe",
- Do not tick this option.
NX will though always ( in my experience) print shaded views and images in color, no matter of black and white settings in other places.
Tomas
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
After following the suggestions, and still getting a negative result, I reduced my image resolution on the bottom of the print menu to "medium" with success.
I have a feeling there is some sort of memory or graphics issue with my computer.
Can the lighting be adjusted on the shaded drawing view?
View -> Visualization -> Basic Lights...
...and make whatever changes you want to the intensity and the ON/OFF status of the so-called 'basic' lights and hit OK. Now save your template and create a new drawing. Now when you set a View to be shaded, it will use whatever was set in the Drawing template.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
