How to sweep a feature inside another feature so its "traces" or footprint can be substrac
I have a small feature which I need to sweep/move along a curve.
When the traces of this feature will come in contact with another feature I have to substract them.
Its very much like a milling cam software just instead of an endmill I have a more complex 3d feature.
I don't need to simulate motion, just to create a feature that I can substract from the outline that is left in the model.
I use NX6.
Please tell me if more clarification needed.
Thank you.
I use NX6.
Thank you.
RE: How to sweep a feature inside another feature so its "traces" or footprint can be substrac
It would help if you could show a picture if possible.
Yes, just the outline of the sweep is not a 2d sketch but a 3d solid feature.
how many trace curves are there?
http://www.eng-tips.com/viewthread.cfm?qid=354058
The footprint will not be made of curves.
Its more like an end mill moving in a given path through a block, all the material that was in the way will be gone.
That's what i'm looking for just instead of simple endmill shape I want other feature.
If its still not clear enough I will make an example at work tomorrow and add to this post.
