Edit Material name in site Library
thread561-324034: Edit Material name
Have same issue as refered thread.
I have created new materials and exported them to Library.
Then I want to edit material in Manage Library Materiel.
I can change for example Mass density, but when I try to change first row Name.Description it fails.
After name I entered when i Created material, "Library Definition" appears. Is it not possible to change the name?
I`m using NX 8.5
Brg Mats
I`m using NX 8.5
Brg Mats
RE: Edit Material name in site Library
Thanks for Your answer.
I am aware of that possibility exists, but I would like to know if it can be changed with Manage Library Materials.
Another question is if it possible to change Type after the material hasbeen exported..
/Mats
