drilled shafts containing rebar cages and steel beams
Is the section modulus for such a composite beam calculated by adding the moments of the rebar and the steal section and dividing by the radius distance to the rebar, or by adding the section moduli of the rebar cage and the steel section?
RE: drilled shafts containing rebar cages and steel beams
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
