SPT Values from Soil Description
Afternoon all,
Does anyone know where I might find appropriate (approximate) values of SPT to use based on soil descriptions taken from window samples?
Cheers
BridgeBuilder
RE: SPT Values from Soil Description
That is a bit of a stretch, going in reverse, as the descriptions evolve from spt. However, to give you a 'general' sense:
Sand/gravel
SPT        Relative Density
0-4        very loose
5-10       loose
11-30      medium dense
31-50      dense
50<        very dense
Fine-
<2         very soft
2-4        soft
5-8        firm
9-15       stiff
16-30      very stiff
30<        hard
BridgeBuilder...pdavis1 has given you the ranges of SPT for general classification.  As he indicated, it is a significant stretch to use these in reverse.  As an example, your foundation and sitework recommendations can vary tremendously for a clean fine sand that has SPT values of less than 10 as compared to the same material with SPT values over 20.
This is a multi-parametric evaluation that should be approached from the "other" direction.
