NX 9.0 Select Face Error
I am in the process of testing 9.0 when I change my filter selection to face and click on a face i get a error that NX License Error: license server system does not support this feature [-18]
What is the default setting when selecting a face?
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.0.19(testing)
If you can think it it can be modeled
RE: NX 9.0 Select Face Error
On the license server, there is a logfile which tells what license NX either selected / checked out/ uses or, tried to check out with failure.
It's in the same directory as the license software and "on my license server" it's named "splm_ugslmd.log" but can be named / placed somewhere eles. ( If someone has bothered to.)
The logfile is a plain textfile, the last line in it will report what didn't work.
Tomas
8:16:06 (lmgrd) TIMESTAMP 10/29/2013
8:16:16 (ugslmd) OUT: "solid_modeling" jhutsell@MECHENG9
8:53:33 (ugslmd) OUT: "gateway" rlee@LENOVO-RLEE
9:49:20 (ugslmd) OUT: "solid_modeling" rlee@LENOVO-RLEE
9:49:37 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:50:03 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:55:31 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:55:37 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:55:38 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:55:42 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
9:56:34 (ugslmd) IN: "solid_modeling" rlee@LENOVO-RLEE
12:10:53 (ugslmd) TIMESTAMP 10/29/2013
12:57:06 (ugslmd) IN: "gateway" rlee@LENOVO-RLEE
12:57:54 (ugslmd) OUT: "gateway" rlee@LENOVO-RLEE
12:58:05 (ugslmd) OUT: "solid_modeling" rlee@LENOVO-RLEE
12:58:16 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
12:58:21 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
12:59:13 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
12:59:45 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
13:28:13 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327:10054 ""))
13:28:14 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327:10054 ""))
13:34:21 (ugslmd) IN: "gateway" rlee@LENOVO-RLEE
13:34:21 (ugslmd) IN: "solid_modeling" rlee@LENOVO-RLEE
13:34:25 (ugslmd) DENIED: "NX11100N_gateway" rlee@LENOVO-RLEE (INVALID error code (-9999,333))
13:34:25 (ugslmd) DENIED: "NX11100N" rlee@LENOVO-RLEE (Invalid host. (-9,333))
13:34:25 (ugslmd) DENIED: "NX11100N_gateway" rlee@LENOVO-RLEE (Invalid host. (-9,333))
13:34:25 (ugslmd) OUT: "NX11100N" rlee@LENOVO-RLEE
13:34:25 (ugslmd) OUT: "NX11100N_gateway" rlee@LENOVO-RLEE
13:34:41 (ugslmd) DENIED: "NX11100N" rlee@LENOVO-RLEE (Invalid host. (-9,333))
13:34:41 (ugslmd) DENIED: "NX11100N_solid_modeling" rlee@LENOVO-RLEE (Invalid host. (-9,333))
13:34:41 (ugslmd) OUT: "NX11100N_solid_modeling" rlee@LENOVO-RLEE
13:34:46 (ugslmd) UNSUPPORTED: "NX11100N_nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
13:34:46 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
13:34:48 (ugslmd) UNSUPPORTED: "NX11100N_nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
13:34:48 (ugslmd) UNSUPPORTED: "nx_visual_reporting" (PORT_AT_HOST_PLUS ) rlee@LENOVO-RLEE (License server system does not support this feature. (-18,327))
13:54:28 (ugslmd) IN: "NX11100N_solid_modeling" rlee@LENOVO-RLEE
Ryan Lee
NX 6.0.5.3
There are also PRs logged for the same error if you set to Solid in the filter or for Pattern Geometry.
Log it to GTAC as the more people the log a similar error, the more likely it will fixed quickly. Here are PRs, that I'm aware of:
PR6954723 - Licence Error is raised when setting Type Filter to Solid and using MB3.
PR1958725 - NX Visual Reporting license required to edit 'Pattern Geometry' feature in NX 9
PR2227880 - NX9 - NX Visual Reporting license required to RMB a Mirror Geometry feature
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3.4
NX8.5.0.23 -> NX8.5.2.3 & NX9.0.0.19
( i had this in mind when i wrote the previous post)
In my case the face is from a Extrusion, not pattern nor mirror.
Tomas
NX 6.0.5.3 (NX 9 Testing)
Windows 7 64
Tim Banks
Application Engineer
VMH International
NX 8.5 / Solid Edge ST6
