Harden Metals before Heat Treat
I am looking to use some type of metal to make a valve seat out of, this is a pneumatic valve. The original is urethane type that works well, but I want to make it out of metal without the heat treat process. I have been told that most metals have a hardness of low 20 HRC and anything above that is considered harden metal or harden steel. My thought is to have them made from solid carbide or tungsten carbide which should be hardness of 72 HRC or about. Is this then considered harden metal even though the is no heat treat process?
I has some made from 1018 steel and then coated with carbide and it worked out pretty well, but now I can have them made in solid for about the same cost and faster. Another other option is to have it made from ceramic, but I have looked at that option yet. I have to make these out of something that is not called harden steel or harden metal, long story. Does anyone have input or information on this matter?
Thanks for any help
Thanks for any help
RE: Harden Metals before Heat Treat
You can do it and it works well.
What we kept running into was valve seats made from rolled material that would move during the brazing process.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
