Built-up Box Shape - PJP weld
I am in a situation where I need to make a 5x3 shape with plates because the axial loads are high and the size cannot increase due to glazing profiles.
I have it made up with two 4.25" x 3/4" plates and two 3" x 3/8" plates. I plan to do a PJP weld of the 3/4" thick plate to the 3/8" thick plate. I am wondering if there are any checks to be done in terms of sizing the welds. The entire section is in compression, but has very small out-of-plane moment (around 6 k-ft). A small weld would work for that using shear flow.
Would going with a 1/4" PJP be okay or should I upsize it to 3/8"? The axial load is around 140 kips.
RE: Built-up Box Shape - PJP weld
Sorry, for not answering the actual question, but this was the first thing that came to mind.
www.FerrellEngineering.com
Providing fabrication and erection efficient structural design of connections. Consulting services for structural welding and bolting.
1) End welds to deliver the axial compression to the parts of your column in proportion to their area and;
2) Weld spacing suitable for composite resistance to buckling as well as the applied load.
