In what instances can Bushings be Used in Fuel Gas Piping
Could someone please verify my research on the use of bushings in fuel gas pipe?
My understanding from searching on Google is only malleable iron when reducing more than 1 size is acceptable. No Cast Iron.
1209.5.8.4 Metallic Fittings (Including
Valves, Strainers, Filters). [NFPA 54:
5.6.8.4]
(5) Cast-Iron Fittings.
(a) Flanges shall be permitted.
(b) Bushings shall not be used.
5.6.8.4]
RE: In what instances can Bushings be Used in Fuel Gas Piping
