Dual Unit Dimensioning
Y14.5-2009 ¶ 1.5.4 states "Where some inch dimensions are shown on a millimeter dimensioned drawing, the abbreviation IN shall follow the inch values. Where some millimeter dimensions are shown on an inch-dimensioned drawing, the symbol mm shall follow the millimeter values."
What would be the situation where ALL dimensions are dual dimensions (inch over metric)? It seems the standard adresses a mix of inch and metric dimensions, not a situation where both inch and metric values are included in each dimension. Shouls we still include the units in such a drawing?
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
RE: Dual Unit Dimensioning
.250 [6.35]
I know this doesn't really answer your question about how 14.5 handles this, but just thought I'd throw it out there. BTW, we follow 14.5-1994, but this dimensioning scheme is called out in our customer's drawing standards and in the drawing tolerance block which supercede 14.5.
I do the same as randy64, but I add a note stating what the primary and secondary dimensions are.
Chris
SolidWorks 13
ctopher's home
SolidWorks Legion
As long as you made it clear, you should have no problem.
The bigger question is why? Are there people out there who are not understanding metric? Is it so difficult to stick to one single unit of measurement? Either one?
It isn't that people are not understanding metric but that the company is international and working in only one unit of measurement has been determined not feasible. Not all drawings are affected, but we want to have a clear understanding of those that are.
-Dalai Lama XIV
Dual dimensions do not need the additional unit nomenclature. You may do as Chris does and add a note stating what your dimension units are.
Ben Loosli
mm[inch]
6.35[0.25]
Avoid like a plague, fight tooth and nail.
I also don't like them. We used a CAD package at a prior company that we wrote a program to gather all dimensions and build a conversion table so tey would be listed on the edge of the drawing showing the metric dimension and its inch conversion. We always considered this table to be reference data only. Our machine shop and NC programmers always wrote their programs in inch units. When we switched CAD programs, the new one could not produce the table as easily, so we eliminated it on all drawings.
Ben Loosli
B.E.
You are judged not by what you know, but by what you can do.
Ben Loosli
That's exactly what I am talking about.
B.E.
Change the system to metric and be done with.
DRO's with dual dimension switching have taken a lot of the pain out of dual dimensions. However I always add a note to a dual dimensioned drawing saying that the bracketed dimensions are there for reference, and that the, un bracketed dimensions, are the ones you work to.
This was a major PTA when Britain went metric in the late 1960's , now there seems to be some of this in the USA where companies will tell you loudly they have no problem with metric dimensions, but when you get on their shop floors you find out they do still have a problem with it, especially in smaller shops with older machines. And going the other way do you want 8mm or .3152" there are some dimensions that will round out to 2 decimals, there are others that are a pain. Give the primary units on your drawing, include the other units as a courtesy, then put a note on the drawing saying that.
B.E.
Does ISO support dual dimensions? Yes. There is even a rule for rounding tolerances: the secondary unit tolerance range always fits inside the tolerance range of the primary unit.
In general, the practice is that the secondary unit is stated in brackets. I'm not sure if that is from any current standard.
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
I'll try the argument in your blog and see how well it is received here.
-Dalai Lama XIV
