hand brake turns with AWD
On most Subaru forums there are discussions that some model 'Roo have a center diff unlocking feature when hand brake is applied, inherited from the models designed to meet some kind of Rally homologation.
With an open center diff I picture locking or slowing the rear wheels significantly would cause the front wheels to try to rev way up, or the engine, or something if the clutch remains engaged. I picture that trying to suddenly snap the front tire(s) loose, and not what I'd want to happen in the middle of a stunt. Not that I'm likely to buy an AWD vehicle anyhow. But maybe I'll try to gently beat up a rental car someday.
1 - Am I misunderstanding something?
2 - Are most AWD vehickles incapable of hand brake turns?
thanks,
Dan T
thanks,
Dan T
RE: hand brake turns with AWD
Source: I engineer and build rally cars for a living.
I always feel like inexperienced drivers rely on a lot more hand brake and therefore this may be more of an issue. A good driver in a well balanced car only needs the e brake on the tightest of corners or the occasional rare moment. Even then when you are at the very limits it takes very little to get the rear end to step out and then for the most part you control it with gas and brakes.If you are riding on the gas and the ebrake for more than a split second you took the corner too slow and left unused units of traction on the table. More often than not proper weight transfer is plenty to get the slip angle you want. If that's not enough then for good drivers there is always the Scandinavian flick. If that's not enough then a light tap on the e brake may be needed.
This suggests the center "diff" on some Subarus is actually a clutch pack, and not a geared differential at all.
http://www.stanleysubaru.com/blog/2012/march/22/ho...
Sounds kind of wear prone and het generating if it is really providing some significant torque transfer at all.
Basic Geared differentials don't "slip." Their left/right or fore/aft output shafts can rotate at different rpm, but the average of those rpm will be the input rpm.
Seems like modern AWD is chock full of viscous couplings and other gizmos.
A far cry from Jeep's original full time AWD Quadratrack which I think basically had a center differential fitted with a clutch pack similar to a positraction except that could be manually locked by vacuum to become 4 wheel drive when "needed."
So an active geared centre diff, which unlocks electronically when a handbrake turn is needed, sounds entirely logical to me.
Regards, Ian
If in gear, At the same time as the engine (the inertia multiplied overall gear ratio^2) is being slowed, the front wheels are trying to be accelerated. When traction is low one or both of the front tires will more likely spin. Probably Not the best thing when initiating a turn or mid corner.
if in neutral, most of the "engine" hardware disappears, so all that is lost is the ability for the front to provide tractive force to maintain speed while the rears are providing some drag.
It sounds like my OP suspicions regarding most AWD and recreational handbrake turns remain somewhat valid.
Supposedly Erik Carlsson's technique with SAABs was left foot braking and full throttle, which also produced somewhat of a net rear wheel brake effect to get the rear end to rotate/move outward.
3;18, 5:00, 11;00, 12;47 - 13:00, 18:39 here -
http://www.youtube.com/watch?v=gKxRiP2RLQs
I'm thinking that AWD and especially the various smart traction controls might make that ineffective too.
Cheers
Greg Locock
Front or rear?
Regards, Ian
Cheers
Greg Locock
