dowels through shutters
I have 2 perpendicular walls which for some reason cannot be cast simultaneously and according to design drawings the connection between he two walls is a stiff connection, thus dowels must pass through shutters is there any way to do this (other than couplers)? with considering a dowel every 10 cm(I prefer not to drill the shutters). looking forward to hear your thoughts..
many thanks
many thanks
RE: dowels through shutters
my case is how to access T16 dowels @150 mm from the pit side to the core leg. the pit side will be executed before the core leg.(without interrupting the shutters if possible )
Or you drill your shutters (formwork).
Or you post-install adhesive dowels which aren't as reliable.
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
thanks for your time
Don't worry about subcontractors nagging, just pull them into line. Isn't that your job?
Actually what I worry about is to keep smooth relationship with subcontractors, and if I can find alternatives to reduce there work load and gain time, that would be an advantage for me and might be usefull later on.
hokie66, JAE, paddingtongreen it is an honor for me that you are reviewing my thread
