Bootstrap Capacitor For High Mosfet Switching
Hello All
For any one new joining this discussion here are the links to my previous questions.
http://www.eng-tips.com/viewthread.cfm?qid=350101
http://www.eng-tips.com/viewthread.cfm?qid=350473
So that being said i am currently in the part of the design stage where i need to choose the bootstrap capacitor value.
Done a few calculations myself, as always need to verify my math.
Spec:
Mosfet Driver IC - IR2110
Mosfet - IRF3710
Bootstrap Diode - UF4002
Frequency of switching - 200 KHz
(The initial idea was 500 KHz but then most design by TI and ST had the frequency at around 200 KHz. So it made me think may be at that frequency the switching losses may be high. Not sure, so came down to 200 KHz)
As per the attached App-Note the bootstrap capacitor is to be calculated using the formula given in page-6.
http://files.engineering.com/getfile.aspx?folder=0...
Voltage across low side mosfet - RDS(on) X Current
23mOhm x 10A = 0.23V
Voltage across low side shunt - R X I
1.25mOhm x 40 A = 0.05V
VLS = 0.23 + 0.05 = 0.28 -> lets make it 0.3 to be safe
Qg = 130 nC
freq = 200 KHz
Icbs = 0 A (non electrolytic cap)
Iqbs = 230 uA
Vcc = 12 V
Vf = 1 V
VLS = 0.3 V
Vmin = 2 V
Qls = 5 nC
Substituting the values i arrive at 61.184 nF
As per App-Note DT98-2 the capacitor value obtained should be multiplied by 15 to reduce the risk of overcharging
http://files.engineering.com/getfile.aspx?folder=9...
Hence the new value of bootstrap Capacitor - 917.759 uF --> nearest value 1uF
Please check and let me know if i have done the math right
Spec:
Mosfet - IRF3710
Qg = 130 nC
freq = 200 KHz
Iqbs = 230 uA
Vcc = 12 V
Vf = 1 V
VLS = 0.3 V
Vmin = 2 V
Qls = 5 nC
Gokkul
RE: Bootstrap Capacitor For High Mosfet Switching
Z
I know that, i just need someone to verify. Cos implementing the circuit will take some time and if it fails i will have to do the process again.
So i am just trying to check if my calculations are correct.
Gokkul
