Wheel/Tire Balance Engineer
Does anyone have any suggestions on where to source an experienced wheel/tire balance engineer? I'd appreciate any help. Thanks!
RE: Wheel/Tire Balance Engineer
I'm not quite sure what you are after. What would this person do exactly? FWIW I was responsible for wheel/tire balance engineering at an OEM, and wasted most of my time investigating why the balance weights fell off, the actual balancing process was handled by a semi skilled line worker and a machine. It took about 15 minutes to train a new one.
Cheers
Greg Locock
Yes, what are you looking for?
If you have a question, ask. If you need consulting help, I'm sure you can find one by googling. If you are soliciting for a job, then there are better ways to do that.
