Unique U Channel Dimensions
Good day All,
Can anybody give me a hand in order to find out what kind of steel channel it is - 66 x 38. Depth is 66 mm, width is 38 mm. Flange thickness is enough big comparing with other king of U channels around 25-26 mm. By the way flanges are not parallel.
These dimensions have been reached as a result of my survey on existing structure. But depth and width are 100% correct. Web thickness can vary only 1-2 mm.
Many thanks in advance for contribution.
Ulvi.
Ulvi.
