Fill the gap or hole in the NX8
Hello All,
I need one information to know please
Is there any command which is equivalent to fill surface in catia V5.
I use N-sided surface if i have a non planer closed curve. and i use patch if there is non planer hole in the surface .
But other than this if any body knows other commands please let me know. because i am not finding exactly the alternate to fill surface in catia V5
I am using Nx8
Thx
BGD
I am using Nx8
Thx
BGD
RE: Fill the gap or hole in the NX8
If so we use the "Trim and Extend" function. Set type to "By Distance" and put in a value larger than what would be needed to close the hole.
This function can be found at...
Insert -> Trim -> Delete Edge...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for your answers.
@JurgenKreisel
Trim and extend works for the regular shape hole. if it irregular it wont work(please correct me if i am wrong)
@JohnRBaker .
Yes delete edge works perfectly. however i need to fill the closed 3D curve like we do in catia v5 with Fill command .
Now to achieve this i am using N-Sided surface. Please let me know which are the other comands other than through curve mesh( complicated when a curve is a single) and N-Sided surface.
I am using the UG NX8
I have attached the UG Nx part File
Thanks in advance
BGD
