CATIA Code for Geometrical Sets
Here is the macro I am trying to create
I have drawn the geometry in geometrical sets and also defined parameters and formulas to derive that geometry. Now I have an excel input file with 302 data points which I would like use to derive those parameters. So for one set of data point I will have one geometrical set and so on. then I will have set of points in space and then I would like them to connect (line or smooth curve) through VB. Let me know if it is still not clear, I would love to explain more.
I am trying to create the for loop in VB but it is not at all working, can anyone help me getting the right code. Please....Here is my code:
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set objExcel = CreateObject("Excel.Application")
Set workbook = objExcel.Workbooks.Open("C:\data\Projects\Track_CATIA_coe\track pack\Interpolation NEW\Result\interpolation20130701115228.xls")
'UPDATE ABOVE ADDRESS AND FILE NAME TO LOCATE AND EXECUTE CORRECT WAY POINT XLS
For loopcount = 2 To 3
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item(loopcount - 1)
Dim hybridBody2 As HybridBody
Dim selection1 As Selection
Set selection1 = partDocument1.Selection
selection1.Add hybridBody1
selection1.Copy
selection1.Add hybridBody1 ' Add the Set where the copied data will be pasted in the selection
selection1.Paste
'Set hybridBody2 = selection1.Item(1)
'UPDATE NUMBER OF ITERATIONS EQUAL TO NUMBER OF TOTAL ROWS IN THE WAY POINT XLS
Z = objExcel.Cells(loopcount, 2).Value
X = objExcel.Cells(loopcount, 3).Value
A = objExcel.Cells(loopcount, 4).Value
C = objExcel.Cells(loopcount, 5).Value
Set Parameters1 = part1.Parameters
Set Length1 = Parameters1.Item("X")
Length1.Value = X
Set parameters2 = part1.Parameters
Set Length2 = parameters2.Item("Z")
Length2.Value = Z
Set parameters3 = part1.Parameters
Set angle1 = parameters3.Item("A")
angle1.Value = A
Set parameters4 = part1.Parameters
Set angle2 = parameters4.Item("C")
angle2.Value = C
part1.Update
Dim product1 As Product
Set product1 = partDocument1.GetItem("Part" & loopcount)
aa = loopcount + 1
product1.PartNumber = "Part" & aa
part1.Update
'UPDATE ABOVE ADDRESS TO LOCATE WHERE THE RESULT CAD FILES SHOULD GO...
Next
CATIA.ActiveDocument.SaveAs "C:\data\Projects\Track_CATIA_coe_Amit\track pack\RESULT 28 MM\" & loopcount & "section.catpart"
End Sub
Sub CATMain()
selection1.Copy
selection1.Paste
Length1.Value = X
Length2.Value = Z
angle1.Value = A
angle2.Value = C
part1.Update
aa = loopcount + 1
part1.Update
Next
End Sub
