Reducing Dimension notation size in drawings
When placing a dimension in a drawing, the size (scale) of the dimension is huge. I used to go to
tools>options>document properties>annotations and place a check on the option "always display text same size"
or something like that.... however I don't see that option. Any suggestions? Thanks. Using SW 2013.
RE: Reducing Dimension notation size in drawings
"always display text at the same size" is grayed out. Any suggestions? Thanks
You need to set your annotation font in the document properties of your document, and probably also of your drawing template.
-handleman, CSWP (The new, easy test)
