High Power High Frequency Supply
I am wondering if anyone knows of any manufacturer (anywhere in the world) that can produce a high voltage, high frequency power supply of the following specifications:
20-35kV peak
2-5 kW output
40-60kHz ouptut
single phase or three phase input it doesn't matter.
Thank you
20-35kV peak
2-5 kW output
40-60kHz ouptut
Thank you
RE: High Power High Frequency Supply
Tesla coils use an air cored resonant transformer where the voltage increase is a function not of the turns ratio but of the ratio of L2/L1. It has very loose coupling and is highly inefficient. I am looking for efficiency in the range of >80%.
I wonder if this is even possible?
On the order of 245k ohms load. Piezoelectric transducer?
Try contacting those in the field of high power, underwater sonar systems.
Thanks.
http://nautelpower.com/solutions-high-power-solid-...
Check with Instruments for Industry (www.ifi.com). They make some standard amplifers in this frequency range and may be the kind of company that can make a modified standard product for your application.
What is the application?
What is the load, exactly, or is that Top Sekeret [sic]?
