Sloped Top of CMU Shear Wall
I've had a contractor request forming and pouring grout in place of cutting block at the top of a CMU shear wall where the roof deck slopes. The contractor would like to stop the CMU 8" below the low point of the sloped wall, place the bond beam at that elevation and then pour 8" to 16" of grout (the wall slopes a total of 8"). Everything else in the attached detail would remain the same. In concept, the approach seems acceptable, but I'm not sure how this would affect the shear transfer through the wall or any uplift loading. I'm thinking if the bars themselves could transfer the shear load and could resist the tension from any uplift with proper development lengths that would be sufficient. Has anyone had any experience with this? Any comments would be appreciated.
RE: Sloped Top of CMU Shear Wall
Are concrete tie beams not common in your area?
