Functions show only and select constrained to
Greetings all,
Hopefully somebody can help me, if not im sure I will manage. At my old job I used the CAD program SolidEdge, at my new place I use Pro-E. While Pro-E seems much nicer there are a few things I miss from SolidEdge, the two main ones being the functions “show only” and “selected constrained to”. They may not seem immediately useful but they really helped when I would have a large assembly. I could select one part and immediately find everything that it was constrained to, and then use show only to hide everything else from view. I mostly found it useful to constrain other parts or check how something was going to fit in the overall assembly.
I do not really have any hope that there is an easy way to replicate the “select constrained to feature”, but does anybody know if there is an easy way to do “show only”. I am aware of the simplified reps but they don’t seem very quick (although I could just be using them wrong). I have created a few mapkeys (not using scripts) but they don’t seem like they would be able to do anything close to that function. Maybe a mapkey script could do something like this? I have not written one but if somebody has some examples or knows where I could find some it would be a great starting point.
Mike
RE: Functions show only and select constrained to
You can right click a component or feature and select Global Reference Viewer to see full info on related features components. for items selected you'll get info on parent features and child features and info on which edges faces planes are being used internal or external to your immediate assembly.
This used to be called Info > Parent/Child.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
I don't setup my components on individual layers, but if you did you can "isolate" a layer where only it will show and every other layer will be hidden. It is non-intuitive but you can isolate several layers and the things on those layers will show and all other layers will not be displayed. This would allow your "show only" function. I tend to just use show & hide, I think it's probably just as fast as using layers. I would not waste the time setting up simplified reps for this.
