Move sketch in 7.5
Move sketch in 7.5
have an existing part being worked on. had to add a small clip.
set up a plane and datum axis. placed sketch on plane and datum axis. created small clip with sketch and extrude.
small clip needs to move.
edited plane and datum axis to move along the curve to new location.
sketch does not move. how do you get the sketch to follow its parents?
in catia this is a simple intuitive process. Painfully obvious that the dolts that write nx don't actually use nx.
RE: Move sketch in 7.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
For this instance is it possible to get the sketch to follow the plane and datum axis?
I have used the browse window in an attempt to get the sketch to move however nothing works as I am expecting it to.
When using the reattach button the sketch move to body plane and the diameter of a circle in the sketch increases 100 fold.
