Testing of EHV cable connection to transformers
Whenever EHV cables (72.5-550kV)are directly terminated to transformers, it is done through a cable pothead protruding in to an oil filled cable box.An oil to oil bushing will take the transformer winding lead to cable box and a disconnecting lead will be used to connect the bushing ternminal to pothead terminal.My questions
1) Today what type of cables are used at this voltage? PE, HDPE, XLPE, EPR ? Trust oil filled cables are no longer used.
2) After the installation work, should the cable and connection to be tested after removing the connection to bushing?As per IEC 62067-2011 Power cables with extruded insulation and their accessories for rated voltgaes 150KVto 500 KV -Test methods and requirements, two tests are recommended after installation- one DC voltage test between sheath and ground and another AC insulation test.(220 KV cable 180 kV Ac for 1 hour or 127 KV for 24 hours.) Are these tests are done always after cable installation? or only 10 kV Dc test only?
