Report data without headings
Hi everyone,
I'm varying some parameters in my model to see their influence. So I import the data into matlab to use them and plot different things. However, when I create the XYdata and then export them into a .txt file, the "problem" is that the first lines are the label of the XY data and the first column is the actual number of the step. Is there a way to get rid of that and to have only the data? I'm asking because it takes time to always delete the parts in order for matlab to be able to read the file...
Thanks in advance for your help!
