journal help
journal help
journal help
Could someone help me with a simple jourmal file.
I'd like to "up-rev" my drafting attribute "REV" with a simple push of a button.
I'd think its a simple "if - then" type thing, where if the value is ORIG then it changes to A, if A then B, if C then D, all the way to Z (omitting I,O,Q,U) , then, if Z then ORIG.
Any help appreciated, (or similar examples ripe for modifying)
RE: journal help
someone......please......
I tried to use an existing journal, and add what seemed like something suitable, but it doesn't work
can someone get it to work?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module report_value_of_specific_part_attribute
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = s.ListingWindow()
Sub Main()
Dim dispPart As Part = s.Parts.Display()
Dim title As String = "REV"
Dim value As String = ""
find_part_attr_by_name(dispPart, title, value)
End Sub
Sub Main()
If value = "ORIG" Then
dispPart.SetAttributr("REV" , "A")
' else
end if
End Sub
End Module
RE: journal help
The following was coded for NX 8, it should work on other versions but there are no guarantees...
Below is one way to do what you ask.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow()
    Sub Main()
        lw.Open()
        Dim dispPart As Part = theSession.Parts.Display()
        Dim charVal As Integer
        Try
            value = dispPart.GetStringAttribute(title)
            value = value.ToUpper
        Catch ex As Exception
            lw.WriteLine("error: " & ex.Message)
            Exit Sub
        End Try
        If String.IsNullOrWhiteSpace(value) Then
            lw.WriteLine("revision attribute has no value")
            Exit Sub
        End If
            Try
                dispPart.SetAttribute(title, "A")
            End Try
        Else
            If value.Length > 1 OrElse value < "A" OrElse value > "Z" Then
                lw.WriteLine("error: invalid revision value")
                Exit Sub
            End If
            Select Case value
                Case "H", "N", "P", "T"
                    'skip values of "I", "O", "Q", "U"
                    charVal = Asc(value) + 2
                    value = Chr(charVal)
                Case "Z"
                    lw.WriteLine("current revision is 'Z', modify code to allow for more revisions")
                    Exit Sub
                Case Else
                    charVal = Asc(value) + 1
            End Select
            Try
                dispPart.SetAttribute(title, value)
                lw.WriteLine("new revision value is: " & value)
                lw.WriteLine("error setting attribute: " & ex.Message)
            End Try
        End If
    End Sub
End Module
www.nxjournaling.com
RE: journal help
Cowski,
That works faultlessly in NX8 & NX9 thanks very much, just what I was after...
