Blast load for grain storage of beer brewery
Hi Everyone,
Where can I find the design blast load for grain storage for a brewery? I have found information on blast loads due to terrorism, but not grain dust.
Thanks!
Eric
Eric McDonald, PE
McDonald Structural Engineering, PLLC
RE: Blast load for grain storage of beer brewery
I would think the design considerations would be similar, with the main exception that grain dust explosions can yield secondary explosions when loose material is shaken loose by the primary explosion. Technical references are available for velocity/pressure.
You might poke around Factory Mutual's public guide, Prevention and Mitigation of Combustible Dust Explosion and Fire, FM 7-76, April 2013, available here,
http://www.fmglobal.com/fmglobalregistration/Vshar...
It might yield a search term that could point you in the right direction.
Go to the NFPA standards.. There are several that apply and give good guidance when designing for dust explosions. R
