Solidworks 2013 System Options Revealed
7
6
Thanks to everyone that filled out my poll. There was a lot interest in knowing this information. I will be posting this on my website eventually since I do not have a decent blog (and the fact I don't have time to blog), but until then I have attached the Spreadsheet to this thread post.
Read through it, let me know if you find anything wrong or have any questions. Outside of what I mention on tab 1 and 2 of the spreadsheet every thing else should be correct.
Scott
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
RE: Solidworks 2013 System Options Revealed
Thanks, Scott. Will look through it this evening.
WOW! You have obviously spent many hours researching & creating that information. Very well done.
Thank you for sharing.
Definately worth a star
Thank you Scott!
Patrick
Thanks guys!! I hope it helps all of you.
Berry Plastics
www.scottjbaugh.com
FYI - I am currently working to create an application to take the information in the spreadsheet an export it to an actual settings file (in my spare time). The idea is you can turn the items on an off as you need to then export your info out to a settings file for easier use.
I hope to finish that up in the next few weeks (or months)
Cheers,
Berry Plastics
www.scottjbaugh.com
