Export to JT
Export to JT
Good afternoon:
I 'm trying to export to JT an assembly prt file which has 5 files that are the same element (Instances). When I export it to JT from NX8.5, the program generates 5 independent files. How I can configure the export settings to do this correctly?
Please, see the image attached.
Thank you.
Thank you.
RE: Export to JT
Steve
NX 7.5.5.4
RE: Export to JT
I has changed the line StructureOption as you have said and the result is wrong. Why I this?
Please, 2 new files are attached.
File 1: The export settings of the NX
File 2: An example.(The root file is s17613004d-main.f01.0010.prt)
Thank you
RE: Export to JT
Steve
NX 7.5.5.4
RE: Export to JT
Steve
NX 7.5.5.4
RE: Export to JT
Maybe I didn't explain correctly yesterday which my goal was. My goal is to construct a single file for all instance elements, not one file for all structure. In my case, I have an element instantiated 5 times in the structure, and when I go to export to JT, the program separates me in independent files renaming them as _inst1, _inst2 ... I would like these files remain the same after the translation.
In the yesterday case, the "Y-902500-1580.f01.0079.prt" file has 5 instances in the tree. After completing the translation, the mentioned file is transformed in 5 independent files renamed as Y-902500-1580.f01.0079_inst1.prt, Y-902500-1580.f01.0079_inst2.prt… and I don’t want this.. I want to keep the original structure with the same numbers of the files.
It's possible to do this in NX?
Thanks you.
RE: Export to JT
Steve
NX 7.5.5.4
RE: Export to JT
I will continue looking for the solution. If I find something, I will tell you.
