Tolerance Table symbol
Not sure what I did when I added our tolerance tables to the reuse library but now it takes forever and is accessing a spreadsheet. This happened when updating from NX 6.0 native to NX 8.0 Native. Symbol is attached.
NX 8.0.3.4 in Windows 7
Mechanical designer
RE: Tolerance Table symbol
It seems that the tables are edited by spreadsheet. And also the part is flagged as a custom symbol. ( i run 8.5 so i cannot save it)
One should be able right click the table and select "Edit without spreadsheet" to get rid of the spredsheet connection.
Then I can only close/ save through using "Finish Custom Symbol Edit".
If you can fix the part by the above, Good. Else it's probably a case for Gtac.
Tomas
Mechanical designer
