What is the effect of increase in environment temperature to ZnO arrester (block arrester) 3 kV
Recently, I did an experiment to ZnO block arrester, all results seems to be okay, except the relationship between the increase of temperature, which is when I increased the temperature of the environment the current unexpectedly decreases. From what I read, It supposed to be increase. How could this possible happen?
Can you explain me the reason.
Regards, ELCdude
Regards, ELCdude
