Nodes constrained on arbitrary plane in Abaqus
Trying to do something which I thought should be really easy but cant seem to find anything obvious.
I am trying to constrain a single node, or set of nodes, to lie on a plane, e.g free to slide about within that plane. Translational restraint only. Plane can be defined by three nodes, or a point and normal vector, either/or.
Effectively an axis of symmetry.
Similar to xsymm or ysymm etc, but in an arbitrary direction...
Any takers?
Cheers guys and gals.
RE: Nodes constrained on arbitrary plane in Abaqus
Use a local co-ordinate system defined by 3 points, and retrain the nodes relative to that system.
Cheers Corus, good idea. I guess the local coord system can be input via the keyword *system. Would you know how the boundary is fixed relative to local system in the .inp file, e.g is it a sub option of *boundary?
(unfortunately I am writing this inp from scratch rather than using CAE)
Cheers again.
you have the *transform option to change the csys for nodes, the boundary then works as normal (but in the local csys for those nodes).
yep, that looks like the one. Cheers Corus and sdebock...
