NX8: How to convert Planar, Spherical, Conical etc. to B-surfaces ?
Hi @all,
Being quite a novice in UG/NX programming, I need to program an external application that reads in a .PRT file, traverses through the entities, converts all Faces to (trimmed) B-surfaces (Nurbs) and passes these to another format. Part of the code is a routine processFace as follows:
Since I haven't programmed yet all the basic surface conversions Plane->Nurbs, Cylinder->Nurbs etc., I would be happy to have a general conversion routine in UG/NX that would take a NXOpen::Face as input and create me a Nurbs surface from it, if possible without loss of geometric information (and for most of the basic surface types that IS mathematically possible).
Is there such a conversion routine in UG/NX? I have browsed the docs and this forum for several hours, but could not find any helpful hint. Sorry if this is a FAQ. Any help is appreciated!
CODE --> C++
void processFace(NXOpen::Face* face, ...) {
// (...) misc initializations and checks
tag_t facetag = face->Tag();
UF_MODL_bsurface_s bsurf;
bool ok = (UF_MODL_ask_bsurf(facetag, &bsurf) == 0);
if (ok) { // filled bsurf successfully
processNurbsSurface(bsurf);
else { // no success, need to convert surface individually by its type
NXOpen::Face::FaceType type = face->SolidFaceType();
if (type == NXOpen::Face::FaceType::FaceTypePlanar) {
// get plane data from Face and build nurbs
else if (type == NXOpen::Face::FaceType::FaceTypeCylindrical ) {
// get cylinder data from Face and build nurbs
// and so on for all other possible basic surface types ...
else return;
// (...) now process the loops, get attributes etc.
UF_MODL_free_bsurf_data(&bsurf);
} Since I haven't programmed yet all the basic surface conversions Plane->Nurbs, Cylinder->Nurbs etc., I would be happy to have a general conversion routine in UG/NX that would take a NXOpen::Face as input and create me a Nurbs surface from it, if possible without loss of geometric information (and for most of the basic surface types that IS mathematically possible).
RE: NX8: How to convert Planar, Spherical, Conical etc. to B-surfaces ?
The way I used to do it was to extract a copy of the face-s in B-surface representation.
( Later versions of NX will in a number of features, such as X-Form etc, do a conversion on the fly when one are about to modify/deform the face-s.)
- search for the extract geometry feature, it should have the option you need.
See attached image.
Tomas
Insert->Associative Copy->Extract Geometry
Programming you can use ExtractFaceBuilder Class
Frank Swinkels
I assume that Dottore93 wants to convert everything into B-surfaces because of some logical reason, a guess would be some form of export to a different system which only accepts B-surfaces.
Tomas
Yes, that's exactly the reason.
I picked up Franks proposal and tried the following:
CODE --> C++
bool processPart(NXOpen::Part* part) { // create a ExtractFaceBuilder instance... NXOpen::Features::Feature* nullFeatures_Feature(NULL); NXOpen::Features::FeatureCollection* features = part->Features(); NXOpen::Features::ExtractFaceBuilder* efb = features->CreateExtractFaceBuilder(nullFeatures_Feature); // ... and set some properties which sound reasonable efb->SetType(NXOpen::Features::ExtractFaceBuilder::ExtractTypeBody); efb->SetSurfaceType(NXOpen::Features::ExtractFaceBuilder::FaceSurfaceTypeGeneralBSurface); efb->SetFaceOption(NXOpen::Features::ExtractFaceBuilder::FaceOptionTypeAllBodyFaces); // traverse through the part's bodies NXOpen::BodyCollection* bodyList = part->Bodies(); NXOpen::BodyCollection::iterator itr; for (itr = bodyList->begin(); itr != bodyList->end(); ++itr) { NXOpen::Body* body = *itr; bool addok = efb->BodyToExtract()->Add(body); // Add body to ExtractFaceBuilder bool ok = efb->Validate(); // efb ready to go? if (ok) { // Go! But what to do with the resulting object? NXOpen::NXObject* obj = efb->Commit(); NXOpen::Body* nobody = dynamic_cast<NXOpen::Body*>(obj); // Fails!!! nobody=0 } // traverse through the body's faces std::vector<NXOpen::Face*>& faces = body->GetFaces(); size_t nFaces = faces.size(), i; for (i=0; i<nFaces; i++) { NXOpen::Face* face = faces[i]; processFace(face); } } }Now I'm stuck since I don't know how to use the NXObject* that Commit() returns. dynamic_cast to Body* (hoping to get the new body with the resulting B-Surfaces in it) fails. Any ideas?
Frank Swinkels
CODE --> C++
void processFace(NXOpen::Face* face) { if (!face) return; // face is already of parametric type? not much to do. NXOpen::Face::FaceType type = face->SolidFaceType(); if (type == NXOpen::Face::FaceTypeParametric) { processParametricFace(face); return; } // otherwise instantiate and set the nurbs conversion tool... NXOpen::Features::Feature* nullFeatures_Feature(NULL); NXOpen::Features::FeatureCollection* features = m_part->Features(); NXOpen::Features::ExtractFaceBuilder* efb = features->CreateExtractFaceBuilder(nullFeatures_Feature); if (!efb) return; efb->SetType(NXOpen::Features::ExtractFaceBuilder::ExtractTypeFace); efb->SetSurfaceType(NXOpen::Features::ExtractFaceBuilder::FaceSurfaceTypeGeneralBSurface); efb->SetFaceOption(NXOpen::Features::ExtractFaceBuilder::FaceOptionTypeSingleFace); // ... and perform the conversion. try { efb->FacesToExtract()->Add(face); if (efb->Validate()) { NXOpen::NXObject* obj = efb->Commit(); NXOpen::Features::BodyFeature* fe = dynamic_cast<NXOpen::Features::BodyFeature*>(obj); if (fe) { std::vector<NXOpen::Face*>& nurbsfaces = fe->GetFaces(); size_t nNurbsFaces = nurbsfaces.size(), j; for (j=0; j<nNurbsFaces; j++) { NXOpen::Face* nface = nurbsfaces[j]; processParametricFace(nface); } } } } catch (const NXOpen::NXException& ex) { std::cerr << "Caught exception " << ex.Message() << std::endl; } efb->Destroy(); }
