Dual monitor..
Dual monitor..
4 Studies Show that Using a Second Monitor Can Boost Productivity...
I agree at 100% with this idea.
I use this solution since 3 year ,
and i realy boost my work.
This want to be a suggestion or a discussion.
Advantage for me:
Catalog on the second monitor.
Other program on second monitor.
stop at alt+tab.
Advantage for me:
stop at alt+tab.
RE: Dual monitor..
RE: Dual monitor..
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
RE: Dual monitor..
RE: Dual monitor..
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
RE: Dual monitor..
RE: Dual monitor..
saves so much space compared to having paper copies on the desk.
RE: Dual monitor..
I didn't Realize the advantage
calculating the low cost of a monitor to give it a try (or recycling a monitor not used)
About recycling, how much less paper used.
RE: Dual monitor..
I use the assembly and part navigator on the second screen, but you can't lock them on the second screen. They are just floating around on my second screen. And every time i switch between drawing, part or sheetmetal the part and assembly navigator jumps in front of each other. It's very annoying and drives me mad.
Using NX 8.0 on Windows 7 (64)
RE: Dual monitor..
I started a topic a while ago about the same subject...
In there I have described how I did my setup as I was facing the same issues as VW181.
Maybe you can take it to you advantage as well.
Click me!
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
